Checking oil
I changed oil & filter on a XR600R, Vintage 86'' ,I've got 2 liters in it so far...
I run the engine,let it idle and it hardly shows on the stick, Let it sit for a bit and the level comes up about halfway :D According to what I've read and heard it has plenty oil but, :)
It's not like my BRP, :)
Any more info out there for checking the oil on the smaller BRP :p
it would probly only hold 2.5-2.7 qts. on a completely empty oiling system so if you get nearly 2.5 in it that would be fine after it warms up let it sit for about 5 min i dont screw my stick in when i check it
if that helps you any
