Speaking of valves. . .
Went to our nice groomed track for a day of riding today. Bike cut out and died before I finished my first lap. Seemed to be not getting fuel, and acting like it was flooded at the same time! It would barely kick over and die only with a handful of throttle. Changed the plug, nothing. Swapped ignitions, nothing. Checked carb, nothing. When the bike was cold, it would start, run, start to pop and bog and die. I suspected valves, because I recently stuck in a new head, springs, stainless valves, port work, etc. from RHC. So, went home and found my two exhaust valves needed 3 shims sizes bigger, and one intake valve needed 1 size bigger. Bike ran great afterwards and started first kick everytime. I never had valve issue before, so is this what happens when your valves get out of spec? I guess I needed to check my tolerances after break-in which I had been putting off. . . :)
Amazing how much better these bikes run when the valves are in spec :):) .
696
I installed my new head with RHC SS valves and HD springs in September 04. I rode the bike for about 3 months without checking the valves. The bike started and ran great all 3 months. I only checked the valves in December because it's winter here in PA and too cold to ride, so it was time for maintenance. My exhausts were spot on at .011, and my left intake was at .005 and my right intake was at .0035. For all I know, my intakes lost that much clearance within the first 2-3 rides. RHC said it's typically in all new heads/valves to lose about .002 during break in.
I just did the intakes on my 03 with stock valves and the left side valve was cupping into the head. The power difference between the beat to crap valves with proper adjustment and the new ones with seats cut in for the m and properly adjusted was night and day difference. The bike runs awesome. But do you know if it is after 5 hours or after 10 hours for the first adjustment? Its amazing the difference in power. :) Its like a new bike.
I received my new head in December and due to weather have only ridden it twice a month since. I have never checked the valves until now, so I assume just about 2-3 months of casual (but hard!) riding is about enough time to re-check your tolerances.
you should not have had to put larger shims in to take up clearance they should have been smaller to open up clearance .
Gee, I hope nothing's amiss here. . . went from 235's on the exhaust to 245's, one intake went from a 150 to a 155, the other intake was okay. Bike ran fine today, no problems. Just a little more finicky to start. . . My two exhausts measured .381, one intake .178, and another .229. Can you damage your head by running with loose valves? I barely got it started with my out of spec valves, but did get 2 laps in before the thing refused to start. When I did start it, it coughed, popped and sounded like it was running really rich. The bike ran and started fine today, so you think I'm in the clear? :)
My guess would be that your cam timing was off from the start and when you went back in to re-shim you got it right when you put it back together.
I've run valves about as loose as you did until I got the right shims and didn't have any problems other than some valve clatter once it warmed up.
Either that or the cam jumped time after your 1st put it together (maybe even in the 1st few kicks) and you got it reset when you re-shimmed. How old is your cam chain tensioner? For some odd reason they like to fail after you rebuild the top end. I had one do it and I've heard of others that have had failures just after a rebuild.
I don't think it can be the timing. I've been riding off and on for two months now, no problems. As for the tensioner, it appears good and my bike is only an '04. . .
i dont think theres any thing to worry about if you did not have the ex cam lobe in the exact location when first setting the valves you may have had them loose the first time .Ron
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
