tall bars
I have been asking alot of questions about handle bars and was wondering if there is a way to raise the bars about 1-2 inches on a 02 ttr125l without buying the bbr triple clamps. Can you just buy taller bars, if so from where?
Thanks for all the help!!!!
You can either get ATV bars, or you can just get MX bars that have a higher rise than what is stock. Just measure from the bottom of the bar (where the clamps go) to the top where your grips go. Then go to a website such as Renthal and find a bar that is higher than what you have.
Not trying to hijack your post, but does anyone have the rise(height) measurement for the stock bars?
I couldnt find the stock measurements for my bikes bars, so I just took them off and measured. :)
ATV bars will give you the added height and they are reasonable $$$.
ATV bars usually have way too much sweep.
www.renthal.com/applications.asp The factory TTR bars are around the 118mm height. The 611-01 generic mini bend (about 1.5" taller) looks like it might fit your needs.
