Decompression - What the!?!
I did a compression test on my XR250L and it was 120PSI and 140PSI when I addes a little oil to the cylinder. I was in the process of taking the engine out of the bike and I noticed that the decompression cable was not attached.
Could this be the cause of my low compression? What the heck does the decompression lever do anyway?
Your compression readings look about normal for dry/wet tests on a bike that has some miles and wear. The readings do not appear to show any kind of a major problem. The compression release is full off when the cable is not hooked up. If the compression release was stuck on you would have little to no compression pressure.
