05 WR guards
I want to get the cycra probends for my wr. I dont want the triple clamp mounts due to the amount of work to mount them. How will the fit be on the new renthal bars? Any other suggestions or tips? thanks
I have the Cycra Pro-bends.
The handle bar mount wouldn't work with my Renthal TwinWalls. We went with the Triple mount kind. They seemed easy enough. It seemed harder to cut the grips & throttle plastic thingy :)
Go for the triple clamp mounts, they're far stronger and will give you more room. I had the bar mounts and they will spin when you fall, the triple clamp mounts are solid and never moved. :)
What exactly do I have to buy extra in order for them to work, bolts or that kind of stuff. I was reading posts and people were having trouble getting them on so thats why I was turned off from them. thanks.
Go with the triple clamp mounts, they are way stronger. Plus they'll give you more room. The bar mounts will spin when you fall, and triple clamp mounts are sturdy and will never move. Hope this helps.
Doug
