DRZ400E Carb Removal
Hi,
Just bought the JD JETTING Kit for my "04" DRZ 400e, should be here soon. Does the kit have jetting instructions for differant altitudes? Also whats the best way to remove the carb? its a little tight.
Thank you in advance.
Jake
The JD kit contains jetting instructions for different altitudes.
The way I take off the carb is:
1. Remove throttle cables
2. Loosen front boot clamp and slide clamp forward.
3. Remove rear boot clamp completely.
4. Pry airbox boot back and tuck it behind frame.
5. Remove carb.
ok thanks,
itz gotta come all the way out?
ok, thanks- and replace w/ allen head:)
