Road tires for klr650
Looking for feedback/info on road tires that will fit stock KLR650 rims. Front tires are going to be the problem I figure. What is the biggest size that anyone has put on the rear?
  • Similar Content
    • By J.P.C.
      2014 New Edition KLR650
      Ridden mostly on-road commuting to work.
      5900 miles (will increase as I am still riding it)
      Thermo bob 2
      EM Doo hickey & torsion spring
      JNS skid plate
      SW Motech crash bars
      SW Motech center stand
      Moose luggage racks
      Pelican 1550 cases with Caribou case liners
      MadStad windscreen
      LeoVince exhaust
      Pro taper evo handlebars
      Uni air filter
      Touratech headlight guard
      HTP master cylinder guard
      New Bridgestone Trail Wing tires
      LED dash lights
      Aprilia mirrors
      Top gun 7.4kg rear shock spring
      Jetted for 8000 ft altitude (140 main)
      Extra Parts included:
      Stock Exhaust
      Stock Tires (only approx 200 miles on these before I changed them)
      Stock Windscreen
      Stock Hand guards
      Stock Skid plate
      Stock Mirrors
      16t sprocket
      Stock Rear shock spring
      Carb jets: 138, 142.5, 145
      Bike has been taken care of. Only damage is 2 small scratches on tank from leaning against it with belt buckle. Has been stored outside, but covered.
    • By Patrick McKenzie
      The radiator fan isn’t starting up, even though none of the fuses or connections between the battery, fan and radiator are bad. I figured it has to be the fan relay, but none of the diagrams I’ve seen matched up with the wires on the bike. Does anyone know where the fan relay is for this bike?
    • By hrchins
      Hey Thumpers,
      I am swapping forks and need to know what triple clamps / tripple trees will also fit the 93-96 KLX650r forks. Through some research it looks like KLX300 and pre 09 KLX250 clamps will also fit. But given the ambiguous name of these parts (triple/tripple trees/clamps) doing a search to get good info is difficult. And many of the clamps I am finding for sale are rather expensive so just want to make sure I am getting the right part before pulling the trigger. Thanks for your help!
    • By siscoken
      My Klx400 is a great...fun bike to ride off road with a few highway runs in between trails, but I felt I needed something different if I was going to ride the highway with the occasional off road excursions......so now I own a 2002 klr650. What a world of difference between there bikes, but I believe that between these 2 bikes I now have the one bike I was looking for... if that makes sense.
    • By VersuS
      Hello guys. I just got a while ago a KLX650 1996 with about 34,000km.
      I was in the process of adjusting the valve clearance, they were really out of tolerance so I ordered new shims and when removing the camshaft I had the 2 tensionned mechanism removed (automatic camshaft tensioner, and the spring tensioner bolt).
      I am now in the process of re-timing the camshafts but I'm not able to line up the EX and IN line properly, I always seem to be half a tooth off when positioning the crankshaft at TDC.
      Could it be that i've had the lower chain come out of timing? I might have turn the crankshaft with tensionners removed...
      I am including pictures of the camshaft marks and as you notice camera angle makes a difference but what are your thoughts?
      If i cannot put the marks right on spot, is it better to have the intake valve open half a tooth before, or half a tooth after? and what about the exhaust?
      Thanks
      Sebastien
