[[Template core/global/plugins/realFaviconGenerator does not exist. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] Jump to content
Please Help Me!
I Own A 2001 Xr 400. I Dream About This Bike Still And I Own It. But To Get It Started I Kick Between 15-30 Times When Its Cold And Twice When Its Hot. I Tierd Of Kicking So Heres What I Have:
Uni Aftermarket Airfilter
Pro Circuit Silencer
The Bike Was Rejetted By A Local Shop But Obviously Done Wrong. "any Help Willl Be Much Apperciated", Says My Leg.
Sounds like the pilot circuit is lean. First try adjusting out the fuel screw and see if that helps. If it doesnt then you might have to go up one size pilot jet.
Your airscrew should be between 2 to 2.5 turns out and check the pilot jet is not gunked up and it should have between a no 55 and 60. Also replace your spark plug.
does it fire after a few kicks and then stall or die as soon as you touch the throttle?
If so go up on the pilot. I would get both a 58 and 60.
You do not have to remove the carb to replace the pilot jet!!
Remove the seat and tank
Unclip the throttle cables from the frame
Drain the carb
Loosen the intake and air box clamps
Rotate the carb bowl toward the left side of the bike and remove the drain and overflow black plastic tubes. (if carb won't rotate enough disconnect the throttle cables)
Remove the three bowl screws and bowl
Change the pilot
Use a dab of grease to hold the main jet baffle in place
Put the bowl back on etc.
To swap the pilot all you have to do is drop the float bowl and go.
The main can be swapped by simply removing the drain plug.
On an average day I can switch both in less than 10 minutes.
