When to adjust valves on DRZ 400
Does anyone know how often the valves have to be adjusted on a 2003 DRZ 400 Dirt version. I have herd lots of horror stories about the Hondas and the Yamahas 250s and 450s. Thanks....Baz400
Do a "search forum" use "valve clearance or valve maintenace" and it will tell you everything you need to know. And, no the DR-Z does not require the service to valves as some of the other 4-strokes but you should probabaly check clearance at least a couple of times a year. If all is well you will find nothing changes much with the shim-under-bucket design. Some guys in this forum have many thousands of miles on original valves. I just re-shimmed my 2000 "S" at 5200+ miles and it was still in "spec" but was advised to run toward the loose side of the spec. Checking clearance and re-shimming is no big deal...especially if you buy a service manual which should be one of your first "adds" to the bike in my opinion. Good luck... :)
For good measure:
-atleast twice a year
-after break in
-after installing any sort of aftermarket cams
-also get a Manual Cam Chain Tensioner (MCCT) if you don't already have one. How to's are on TT just do a search. Super easy and great protection for the price.
I checked mine after 3 months of use (2200km) and one valve was out of spec. Two others were marginal.
I checked mine at 5,200. One IT and one EX right at the tight end of the tolerance.
quote * I have herd lots of horror stories about the Hondas and the Yamahas 250s and 450s. *
the DRZ is a modern bike, as comparable to the XR when come to maintenance.
don't worry too much about that.
3or4 times a year should be ok. I don't check as often as burned does because I don't bounce it off the rev limiter like he does. The man is a throttle heavy son of a gun. He can ride good enough to back it up so why not. I'm getting old now and trying to stay alive on the beast he built. It's a blast to ride though. I love that 03 kicker, the best bike I ever owned and it snowed today. What a royal bummer, it's really coming down to. looks like the bike is going to sit for a while now. prairiedawg :p:):)
I didn't check mine until after the first year, I adjusted all 4 as they were on the tight end, 2 were requiring adjustment, the other 2 were at the low end of the spec, but since I was changing cams at the time I did all 4. Once you have done it once you will find it is easy, you just have to take your time and be careful and all will go well. I can now check my valves within 1 hour. :)
Mine was 4 years old but only 1,000 miles when I got it. Rode for another 1500 miles then checked. All in spec. Odd that one report of an almost new 2004 that went out of spec. I think the manual calls for the first check not at the 600 mile service (???) but much after. Weird.
Checking is easy and quick. I doubt it'd take you more than an hour even going very slowly the first time out. No reason to put it off.
The manual doesn't say to check it till 15000 miles. But ya, one of my valves were out and I only had 2200km. It's worth checking them regularly. I just hope my valves don't keep getting tighter on me.
3or4 times a year should be ok. I don't check as often as burned does because I don't bounce it off the rev limiter like he does. The man is a throttle heavy son of a gun. He can ride good enough to back it up so why not. I'm getting old now and trying to stay alive on the beast he built. It's a blast to ride though. I love that 03 kicker, the best bike I ever owned and it snowed today. What a royal bummer, it's really coming down to. looks like the bike is going to sit for a while now. prairiedawg :):p:)
Only thing snow does, is make you wrap up more, get on that beast and enjoy it, snow is great, makes the "offs" a lot more softer :D
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
