03 "S" CCT Questions
Hi, I'm installing an intake cam this weekend.
Seems like no problem except I am unsure about the cam chain tensioner.
Is it manual or automatic? I have instructions for the auto but I'm unsure about adjusting the manual.
I have seen threads on the MCCT and I'm not sure if they are for the aftermarket part only.
Anyone able to help?
Thanks, Glen
You have an automatic. All manual tensioners are aftermarket.
Remove the cap. Remove the spring. remove the tensioner assy. Release the ratchet and retract the push rod. Installation is: install the tensioner less spring, install spring, install cap, crank the motor forward for the tensioner to self adjust.
