xr250 fork
My wife got recently a 2002 xr250. The fork seals are leaking so I got started on changing them...Now, am I blind or retarded or is there no dampening adjustment on this fork??? :) Other things I need to know are the oil level and recomended oil weight. I thought the fork was somewhat soft. Anybody got experience putting in some heavier then honda recomended oil weight?
Any help will be appreciated
You is right.
No rebound.
Standard oil level is 82 mm from top of fork tube.
Stick with the stock 5 wt. fluid and soften the compression so she can use all the travel. If she's a woods rider and under 200 lbs. she won't be able to bottom the front forks even if you go all the way out on the compression, and that is just what I would do.
While your at it set the rear sag to between 85 - 87 mm, soften the compression on the shock the whole way and slow the rebound down.
I had to run out into the garage to take look at it. Didn't even see the compression adjuster before. :)
I was expecting a normal metal screw(I assume this would be normal) clicker. In the xr there is some rubbery :) plate thingy with missing corner on the bottom bottom of the forkinside the hex. Do you just shove a small screwdriver in the missing corner and turn it around??? that rubbery plastic gizmo feels pretty flimsy..
The rubber thingy is a protective cap to keep the screw that is beneath it from looking like hamburger. Pry it out and do your adjustments.
Do you have an owner's manual with the bike? Haven't read mine yet - got a new xr250r last week - I would imagine it has an illustration that will make it all clear.
There are rubber plugs in the bottom of the fork that keep the compression adjuster from getting jammed with dirt, etc. Take a small flat blade screwdriver and pop these out. After they are out - you can use a little bit flatter screwdriver to turn the compression adjuster. (Stick it up in the hole in the bottom of the fork until it fits in the slot).
To get consistent settings - Turn the compression all the way in until you feel resistance. Then back out 14 clicks and you should be in the ballpark.
-jeff
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
