Which mods are best first?
Hello out there. I just bought my first Suzuki. It's a 2001 DRZ400. I'm totally new to these and am wondering where to look for the best mods to do to it for more power, etc. If you have any good places to look, or just advice, please share it. Thanks!
-Jesse
Howdy...Get rid of the ACCT (auto cam chain tensioner) and install a MCCT (manual cam chain tensioner) available from www.bitechmachine.com This will keep your motor from self-imploding when the ACCT goes bad. One of the only really bad defects on this bike, especially the early models like yours and mine. Read Bronco's FAQ at the top of this forum that describes many mods. Case-savers, skid-pate, round-off the edges of the shifter to prevent it from going through the case in a minor fall. Dyno-jet kit, etc. I still run my stock exhaust opened up a little. If you like it quiet you can't beat stock but there is a great selection of after-market headers and pipes. Ya got a service manual? That's the first thing I'd buy. From then on it depends on how much money ya got! Search the forum...almost 250,000 posts dealing directly with the DR-Z in all its forms. The TT Store is a good place to shop. Good luck... :)
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
