Changing sprockets?
I ride a 2000 XR400R. I want to go bigger on the rear sprocket. I mostly hillclimb and ride single track trails. Can anyone tell me what sizes to use and a good brand?
Thanks!!
I did a lot of research on this recently, and decided to go with a 48-tooth rear sprocket (stock is 45 teeth). Dwight Rudder recommended this size, and I figure he knows what he's talking about. I should be able to lift the front wheel easier, and stay in 3rd gear more often (the trails I ride require a lot of shifting between 2nd and 3rd).
I bought the Ironman. They're supposed to be one of the best made, very long-lasting, but they ARE expensive (~$100 for mine). They look cool too, with high bling factor. Also, you should buy a new chain and front sprocket too if you're getting a new rear sprocket -- buy all 3 new, at the same time.
If you go with a 48-tooth rear, I've heard you need to add an extra link to the chain because the standard size (120 links?) is too short... I bought an extra master link to serve this purpose -- still not sure if that will work, but I'll find out.
(I can't actually tell you how good the 48-tooth is, as I haven't installed it yet. Just got it last week and haven't had time to put it on).
up three on the rear is equal to down one on the front. if you are just keeping the 15 front and going to a 48 rear. just change the front to a 14. you won't need a new chain
Go with Ironman sprockets, I have them on my bike, and had to use my old worn out chain for about 4 rides, they still show no wear. I have probably put about 20-25 hours on the sprockets, and they are still in perfect shape. if your sprockets and chain arent worn, just buy an ironman front sprocket, its worth it.
If you have your heart set on the 48 tooth then you can choose any stock replacement for an XR650R (since it is the same bolt pattern and ships with a 48).
i just bought a 14t and a 45t
with the 45t on the rear, i can just swop easily with either the 14t or 15t
With hindsight and all this good advice, it sounds like I should've gotten a 14 front and new Ironman 45 on the back... I like your idea about that combo keeping you more flexible, since it's easier to change out the front than the back.
Ah well, live and learn. :)
Hey, does going smaller on the front increase the wear on your slider, from the chain?
xrmike, a 14 won't show much more wear than a stock 15 but a 13 or 12 might. I have run the 14 alot and don't notice enough to worry about.
I was warned by many that going to a 12t front on my XR250 would cause slider wear problems. I've been running a 12t front for about 18 months now and the slider still looks great (around 3,500? miles). I would not worry at all about a 14t on an XR400. I did have to replace the chain and sprockets about a month ago (Sprocket Specialists front sprocket was wasted). I'm now using a PBI Racing 12t and SunStar rear with Renthal R1 chain so I'll see how this combo works. I may end up replacing the setup soon with a 13/52 since I went to the 280 kit.
Hmmm. I have always been able to pull taller gearing with a 280 kit. I like running 13/46 or 13/45; My best friend likes running a 14t countersprocket instead - 14/48. You won't have to shift as much and as I said it will "pull it" (unless you weigh more than 240 pounds...).
- jeff
I Ride A 2000 Xr400r, And The Sprockets Are Stock. What Would Happen If I Went Down 1t In The Front And Up 3t In The Rear?
- jeff
Where I ride I have no need for top speed. I don't have anywhere where I can run 6th wide open so I gear the bikes down to where the gears are usable. I like a very low crawling gear, I run 2nd/3rd/4th in the tight stuff which leaves 5th/6th for getting me from trail to trail. I've found with the 280 kit I am in 3rd/4th much more, still use 2nd a little and even bump into 5th once in a while. I'd rather be slightly low in gearing than slightly high and I'd guess 51/52 on the back with a 13t front should do the trick. 13/50 is still to high for my liking.
litrob, you will just get more torque and less top end speed. 1 down on the front = 3(approx) on the rear.
Does anyone run anything bigger than a 48t rear, and if so did you leave the front stock?
