IMS 3.2 and Tusk Inline filter Breakage
Just wanted to post this as an FYI...
I put a tusk inline filter... my feul line because the place I was riding has a lot of fine silica sand. A friend of mind suffered a stuck throttle there so I thought i would play it safe.
Anyway, it broke on me. You can kind of see where the hose is coming off at a weird angle, right at the top of the filter...
With the benefit of hind sight I should have put it on the straight part of the feul line.
I have also learned that more parts = more potential for failure.
Luckly my bike ran the whole ride OK. I noticed right before I washed the big yellow pig. (I say that with much love)
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
