TeraFlex Rear 140 -80-18 On Stock Whls
Buying a Rear TeraFlex 140-80-18 for DRZ400
Has anyone used this tire for stock drz400 whl?
I have 300 miles on one on my 03 S. Great tire no issue with stock rim you will be surprised with its hookup :naughty:
Yep, stock rim, stock inner tube. Works great. Wish they made front tires too!
I put a Kenda Trackmaster on the front. I also added a rim lock front and rear.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
