First Imp: HF tire changer
finally tried out my Harbor Freight Tire changer.
Not real impressed. Did the front first, had a few difficulties and learned a few things:
-the top arm of the changer is useless, so I removed it
-use straight dish soap as a lube rather than a mix of water and soap
-bolt the stand directly to floor to get more leverage
rear tire
-Studded tire was extremely tough to remove due to the inner street tire liner stiffening the tire.
-put the new tire under the hood of a running truck for twenty minutes to warm/soften/make more pliable.
-use a c-clamp to keep the unworked side from sliding back off/on.
No pinched tubes on either one.
Not real impressed with the changer.
The stand worked well for holding the tire at a workable height in place. The holders were fairly difficult to get between the rim and tire for tire removal and were also difficult to remove after remounting a tire.
The long tire iron tool that came with it was the best part of the package.
I think my money would have been better spent on one of the other stands that have been discussed on this site.
I found I could change tires faster with irons. I mounted mine on a big plate and that helped alot and getting the clamp off the rim after the change was the hard part. I was actually getting it figured out and then I broke the end off the long bar and haven't used it since. :naughty:
I noticed the end of that long bar looked like it was slightly bent too. probably close to breaking
Too bad you can't just buy the bar from them :naughty:
15 gallon drum :naughty:
