What new clutch
It is time for a new clutch. What does everyone recommend. I ride mostly tracks. 04 CRF250R.
Thanks
I just replaced my basket with a Hinson. The OEM basket was toast. Everything else I went OEM except springs. I went with EBC springs. So far, it's working great.
If you need a basket, Hinson is good, as is Wiseco and PE....
Since you have an "R" model, a hot trick is to run the stock steel plates and fibers...but get one EXTRA steel plate and run it in the middle of the stack. This gives a bit more spring preload for better hookup and also gives a longer wear range of the plates before needing replacement. Mine is working flawlessly still at ~35 hours...
I like the Hinson clutch components, they are very reliable, and they have a lot of experience in the business.
I have a Hinson Basket and Pressure plate. Stock fibers and steels with stock CRF450 springs
previous experience with hinson--good stuff, but like the idea of the stainless steel inserts / barnett clutch basket----seems that would be durable----anybody try that setup?
