Pannier Protectors
I just got a Wolfman Alfa rear bag for my S. Its a great bag, but I have to mount it far forward to keep the right side from hitting the exhaust. Anyone know who makes pannier protectors for this bike. I have a Pro-Moto rack, but they only make the protectors fot the 650.
I bought the Dirt Bagz recently and really like them, they of course come with the mounting bracket to keep them off of the bike. Come with a warranty and all of that. Use them daily for my commute but if I was to go camping I would probably either add a duffle bag on top of them or tank panniers.
I have their rack and will someday upgrade to their side racks, to support pannierz
Thanks for the link. Pricy as hell :naughty: , but I ordered their "original side rack." Its a little more heavy duty than what I need, but it will allow me to move my bag back...and give me more mobility.
I am torn between Dirt Bagz and Andy Strapz' Expedition Pannierz
It's about the same price.. pannierz are waterproof, rolltop, adjustable size,
but no frames.
if i win the lottery... happy trail SU side racks and pannierz and pelican
dirtysouth: can you post some detailed pics of the dirt bagz and mounting
brackets on both sides? the dirt bagz website is horrible!
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
