UFO Installation PICS??
Do you have an S? I am not sure what the e subframe looks like but with the S I mounted mine under the fender but over the sub-frame. The bolts supplied fit the two mounting holes on the back of the sub-frame. Take your rear fender off and you will see what I mean. Here's a couple post that should give you enough info. The second post Linco actually had a good idea I might try when I get some time.
http://www.thumpertalk.com/forum/showthread.php?t=199651&highlight=UFO+tailight
http://www.thumpertalk.com/forum/showthread.php?t=131685&highlight=UFO+tailight
If you still needs pics I can take some tonight for you. :naughty:
I do have an S type. I will look over the links you sent and give it a go. Thanks.
Thanks - I did the installation last night. I used the advice from others found in old threads and it worked great. I am very happy with the look. Much better than the huge stock unit. :naughty:
