05 crf450 need help on JD Jetting.
I have an 05 CRF450 which I had a full DR. D pipe. I ran the Blue needle with great results. Since I have smashed my pipe and I am back to a Stock bike with only the filter screen removed. My bike is telling me I need to re-jet but I'm not sure what to run. I am in Arizona 1,000 - 2,000 feet and the temps are getting hot 90+. Should I run Red Needle? Which Main Jet?
Thanks for the help.
well i can't run the blue needle anymore now because it is getting hot,----i am using the red in the 3rd or 4th and a 172 175 main,
now i am using f&l sp1 fuel also ,---but even on pump you will be close to this ,---4th clip for pump .
That seems a bit rich but I will try the 175mj in 4th pos. Thanks for the help. Is your bike stock?
