TC450 cam specs
Does any one have any info about stock 04 or 05 cam specs or know where I can find them?
Werent in the manuals on the website. Which ones were you refering to?
I saw lash figures but I need actual lift, and duration specs.
Max lift
intake is 9mm
Exhaust 8mm
Inlet specs
Valve open at 55° before TDC
Valve close at 109° after BDC
Maximum valve lift at 115° after exhaust TDC
Exhaust cam Spec
Valve open at 73° before BDC
Valve close at 45° after TDC
Maximum valve lift at 105° before exhaust TDC
This is 05 TC spec.Don't ask where I got the specs from (Factory!)
