Edelbrock tuning after big bore/stroked
I recently had my crank done by Powroll. My 250 is now a 291cc :naughty:
While breaking it in I noticed the stock like hesitation is back, low rpm to wide open.
Once it gets past the hesitation it runs like a raped ape.
There is no poping on decel and I think I have the Idle to 1/3 mixture set close. It was working great with just the 77mm big bore.
Should I give it more pump?
77mm weisco piston
crank stroked by Powroll
Try giving it more pump (quick & easy to do). Also call Edelbrock and ask them as they may recommend you send your carb in to have it bored a bit larger, which may further increase your performance with the combo you have.
qadsan , thanks for the info. will call edelbrock to see what they say
