hot cams timing and jetting
Hi great knowledgeable people if I install the Auto Decompressor Exh Cam made by “hot cams“ on my 02 wr250 can I use the yz timing? the cam is the same for 01-05 yz and wrs. Running the hot cam what jets would you recommend, if I told you I had a staintune pipe and im in Australia so no grey wire or throttle stop. All help appreciated.
If you are properly jetted with the aftermarket pipe, then you'll probably be okay with the cam.
