CRF 450 2005 Exhaust Color
Is everyones exhaust header turning more blue then their 2004 CRF? Im running a stock bike and the header is a brilliant blue it doesnt feel lean though and runs great!
yes thats how they run,---you would be blue to if you had 1400 degrees of hot exhaust gases running through you too,--- its just for years the makers covered it up with thick chrom and or guards or whatever,----your cars and your two strokes all do it too.
its just a motor and hp = heat.
the more hp the more heat, and now everthing is lightweight so nothing is hidden any more !!
True thats what i figured it was just a lot more blue then my 2004 Im guessing a little lighter wall thickness of the header material..!
titainium does not oxidize like other metals when it gets hot ,so it stays clean , to bad it dents so easy or it would the best material for these pipes :naughty:
I'm not sure thats even possible. Unless its titanium foil!
