Best Race Fuel ????
hi, i have the 04 250r, and i want to start running race fuel in it.... i live in alaska, so our pump gas is NOT the best by any means.... well, what do you all recommend? my bike is totally stock.... with the race fuel, do i need to re-jet? also, my buddy has a 2002 wr426f, and he has the free flow intake, with the fmf powerbomb header, and the fmf power core 4 pipe, and up'd his jets... would the same fuel work for him too if we split the cost? thanks for the advice in advance !!!!
Race gas is exspensive but if you want the best I would recomend VP U4. I personally cant afford to run that so I jsut mix 110 octance 50/20 with 91 pump gas.
If you run the U4 straight, you need to increase your main jet size to realize the full benefits. This advice was directly from some VP reps at a race.
Normally and to be safe you should go up one size on the main but...... Sometimes the pump gas is so bad that the bike is over jetted just to make the pump fuel burn so going to the U4 that burns completely does not change the jetting too bad.
The stuff rocks.
Up in Alaska generally your temps are a tad cooler on average that most of us so a fuel like C12 will work well.
Pricing...C12is Twice as much as pump but not the 4 times as much $$$ as the U4. U4 has gone up in price 12%+ at the WD pricing level :naughty: C12 maybe 4%. and the dang frieght has almost doubled since the fall.
I have been mixing c12 with 91 pump ( 50/50) with good results. :naughty:
I was at a race shop last week when they were setting up a bike on their Mustang dyno (just before I dynoed my Cummins turbo diesel 336/685 at the wheels!!!) and they were running U4 in a 400 street bike.
They said it made something like a 3 or 4 horsepower increase, just by changing fuel and jetting for that fuel.
A guy filled his Ford Mustang with it, and it gave something like 25hp!!!
U4 works. I'm a believer. I run it in my bike. On our bikes it should be worth 1-2 hp, and it's much cheaper than a $700 pipe. You'll definitely notice a difference.
Use what you can buy conveniently and on a consistent basis.
I hear that race gas is extremely hard on four stroke engines. Is this true?
Not at all.
It is better since it is easier to jet and burns way cleaner.
I would have said Union 76 until last year. Now that they are gone, VP for sure. :naughty: Steny
The only issues are the lead content, and its effect on valve and exhaust components. There are several opionions on it. Some say the lead will cushion the seats, while others say too much lead will wear the coatings off of the valves.
I took the middle of the road .. and run 50/50. :naughty:
c-12 best all around fuel :naughty:
My brother-in-law get Sunoco leaded race gas(113 octane) for his race car and I've been using that 50/50 in my two stroke. Can I use that instead of C-12?
It is a fair gas. Not the best for a single cylinder bike but it will not hurt.
Race gas from a ground storage tank is marginal for any performance gains in a bike other than detonation deterant.
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
