this bike did not miss, painful crash vid
If the kid tried harder he probably could have pulled off a complete 360 frontflip on his bike!
owwwwwwwww and he was twitching. He will be surfing on how to preload and position himself for jumps after that
I can't view it because of my cyber sheriff at work. Can someone host it with windows media, please?
Ouch!!! Not being a jumper(myself) why did the front drop out like that, it dropped as soon as it cleared...I guess you see why I don't do much jumping, but that front to me just dropped to fast..
He wasn't twitching, he was coughing, trying to un-collapse his lungs...ouch.
As far as why the front dropped, it was most likely because he tried jumping while sitting down...stand your ass up when you jump so you have some room to control the bike in the air. He was at the mercy of that bike as soon as the rear tire left the ground.
I just went back over the vid. The kid was panic reving it right off the face of the jump. maybe his rear rebound setting is jacked?
That's funny. How come I can't save the movie from that page?
man, that was brutal...I'd probably laugh if it wasnt a kid...if that kid ever jumps a bike again, he should start out with a lot smaller jump and stand the heck up...
First time I watched with no sound and assumed he chopped the throttle. Now that I watched it again with sound I guess yall are right. gotta stand up. I've never tried jumping while sitting down - at least a real atempt -vs- "I'm tired and done so I'm rolling this jump" sit down.
At least he was wearing gear :naughty:
He was in too high of a gear too as is evidence by a lack of RPM's (Until he panic-rev'd). Yes, it would of helped to get into attack position too but if he yanked the throttle a bit he would of been ok.
I'm not an expert and make no claims for perfection but I've done a few jumps and the comon ingredients are listed below. Perhaps some more experienced riders can add more details. Approach the jump with enough speed that:
1) you get some air :naughty:
2) you land near where you want to land when you come down :naughty:
3) you want to be in a high enough gear that you still have some power but not reving the engine :D
4) lean forward while going off the face of the jump. :D
5) Stay either constant on the throttle or accelerating a little as you go off the jump. DO NOT let off the throttle like that kid did. sometimes you can let off a little if you really know what you're doing but it's safer to just tap the brakes.
If the front starts to go down give it a little throttle in the air, this will help lift the front. If the front goes to high and the back is going to low pull in the clutch and hit the rear brakes. All this takes practice and I keep practicing this on small jumps before doing it on big ones.
I think that kid probably was going at a pretty good speed and let off the throttle completely as he went off the jump. At his speed I think what happened would be expected. Ironically a more aggressive jumper wouldn't have had the front drop because they would have stayed on the gas. I don't know why he went so fast if that was his first time.
Ya, I looked at it and I thought the same thing as you Flash - that he let go of the throttle at the base of the jump. But when I turned up the sound, it didn't seem like he dropped throttle so I was confused as to why it happened until I noticed he was just sitting on the seat.
What's more confusing is why he was going that fast for his first jump. That vid made me rethink how comfortable I am in the air, hehe.
huh that looked like fun
That is at Parkers track in Hope Mills, NC. We practice there sometimes. It is a supercross style track but has changed quite a bit since then. There are a lot of local GI's that get hurt there because they ride over their heads. I try to stay away from there if i can because they can be very unpredictable. Mr. Parker (guy with the hat on) passed last year on his tractor while working on the track. He was a helluva guy. Used to sit out there all day and drink beer and smoke cigars and watch everyone enjoy his track. RIP Mr. Parker.
Sitting down has something to do with the fact that he ate shit, He needid to blip the throttle off the lip to raise the front end. Do any of you watch supercross? Its called a seat bounce.
Looks to me like he was standing up but the rear end kickup so fast by the time he is off the lip the rear fender is allready hitting him in the butt. He's definitley standing at the base of the jump. Freeze the frame right before he takes off. Still looks to me like he's standing.
He panic reved when the front end started dropping, thats good. His head was up over the bars going up the face, so body position is decent. But he didn't drive off the face of the jump sounded like trailing throttle all the way up till he panic revved it. But I've trailed the throttle on a two stroke without disaster. I also seat bounce jumps all the time, sometimes just to save energy cause its easier to stand after you are in the air. But then again the CRF450 has to be one of the best seated (or standing) jumpers of all time.
My money is on a serious bike set up issue. Like way too light on both compression and rebound. Light compression lets the rear spring compress more when you hit the face of the jump and the light rebound lets it unload fast as soon as the front wheel leaves the lip, starting the nose down rotation.
I had a buddy spend 10 days ICU & lost a kidney endoing a 70ft table. He had his weight back (bad) and the bikes shock was valved & set for enduro work. When that loaded spring rebounded he had no chance. He was destined to endo from that point on. I spent a lot of time studying jumping after his fiasco cause it was a really scary situation. His lungs filled with fluid after a about a week cause he was just lying in bed and couldn't get anything but shallow breaths cause of the kidney pain. It was five days after the accident before the removed the damaged kidney.
Reminds me of my first time ever riding my dirtbike.. I had an XL250 and I hit this huge tabletop-like jump that me and my friend found out trail riding -- while sitting down. Well as I hit it, I did a superman by accident because the jump made me bounce out of my seat and as I came down to land I was still doing this "semi-superman"
Luckily, just a few really bad scrapes and a broken front brake.
The worst part was the slam by his bike following behind him... Ouch...
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
