DR shock
Whats a good after market shock for a 650????
The only one I know of is a Progressive Suspension 420 shock.
Don't believe it is any better than the stock shock.
I'd get a new spring for the stock shock and if that doesn't do it get the stock shock revalved by ESP.
Best mod I ever did.
I installed a Progressive Suspension spring, changed the shock fluid and re-charged the shock with nitrogen. It now works considerably better than "as delivered".
I believe Ohlins makes a shock also. It has .5" of adjustment which translates to a decent amount of raising or lowering of the back end. Probably more expensive, but it's worth it if you off road.
Also try Works in Cali.
