Wiseco 120 BB = race gas ?
Does anyone know if you run the 120 bb piston in a XR 100 - do you need to run race gas? Can you get away with running pump gas? If not - is there another brand that I could use that I don't need to run race gas? Just don't really want to have to deal with dif. gasses with all the bikes! Wiseco seems to be the cheepest way to go - this is for my son's bike.
Thanks dp :naughty:
You can run pump gas if you don't machine anything off the cylinder deck height.
I would use premium pump gas (93-94 octane) if you do need to machine the barrel or head use 2 base gaskets to lower the compresion.
Thanks :naughty:
Is there a reason I may need to have the head or barrel shaved?
Any idea if the bike will be as dependible as stock?
Will it run hot or hotter due to the thinner sleve? Not sure how much room there is for shaving the sleeve down - or how much "meat" is left after milling the sleeve?
Thanks Dan :naughty:
have a 1985 xr 100 with wiseco 120 kit, re-sleeved,cam, and heavy duty valve springs, it rips with super unleaded
Do I need to resleeve the cylinder or can you just boar it out?
What cam are you useing?
Why the heavy valve springs? Floating at high revs?
Does your bike run hot at all ?
Did you have to change the jetting - if so what did you go to?
Thanks for the help!! :naughty:
i do believe you need to resleeve, if you go with the 120 kit, stock sleeve is to thin wont work, i got a cam through engines only near my home in san jose area, there web site is xr100.com, cam came from a company in san rafeal,ca. my weight 230lbs and cam and bore you will need to go with heavy duty valve springs, i did have problem with exhaust valve hitting top of piston before and after new cam and springs, filed piston down some but valve still hits piston. i have been riding it like that for a long time and just dont care anymore, engine just ticks real loud but no problems. bike runs normal temp maybe a little hotter i am not sure, as far as the carb goes i run a late 70s elsinore cr125 carb. it has the same openings as the 200atx or atc or whatever it is that everybody else is using, also run header wrap, uni pod filter, homemade power now, and white bros r4 pipe, hope this helps
It does help.....thanks!! :naughty:
It sounds like a fun bike - I love riding my kids 100s - my son is 9 and weighs 90 lbs so I will prob. just go with the 120 kit. I live just up the Hy from you in San Carlos - who did the resleeveing for you - did you send it out?
Thanks dp
I think it might be easyier buying the L.A. Sleeve 120cc kit from denniskirk.com I was looking and the kit comes with a brand new cylinder already pre bored with the cylindere it from the way they describe it.
Yes, you have to re-sleeve. Most machine shops can do it. Run two base gaskets. The problem of running race or not, mainly has to to with running at peak performance or not and most importantly pre-ignition wrecks havoc on you piston, which can lead to granading the motor. The machine shop can probably take a little off the top of the piston too. As far as reliabilty goes, as long as you change the oil all the time, it will last for a long time. For a cam, you probably should get a mild cam, larger cams require grinding you rocker arms and exhaust valve guide. Combine this with a 1984-85 atc 200x carb and the motor will go pretty good.
Are you saying that I should run a dif. cam with the BB kit? If so why?
And are you saying if I do get a cam - to get a mild one so I don't have to grind the rocker arms?
I talked to DK and that is a misprint - does not come with the cylinder - just the sleeve.
Stupid ? - where do you buy the sleeve?
that sucks. they all come with the sleeve
Or a kitaco kit.
Wiseco or LA sleve have them
  • Similar Content
    • By spezza-125
      Anyways so I got a 1985 xr200r RFVC, and I have heard that the oil really overheats and in some cases people have had their bike (Rarely) go up in flames, however I don't want to take any chances and I heard that there is a way to put on some sort of oil cooler... How do I do it??
    • By Yamiha
      I have a '01 XR200 and i was wondering it anyone could give me a top speed for it. Where i live its more 2 lane highways and things so i cant find a good straight to run it with a car in. Thanks
    • By Quick Draw
      I decided to compile a list of common modifications for the XR200 in hopes of eliminating some of the common questions asked on this forum. These modifications are intended to improve the overall performance of the bike, without sacrificing reliability. Feel free to suggest amendments or things to edit.
      The XR200 is an excellent offroad machine; however, it was for the most part obsolete about 20 years ago. The bike can still be accredited to having probably the best reliability of any full size bike out there. When properly setup and modified, the "little XR" can run with the modern big bikes, especially in the tight and nasty technical terrain.
      INTAKE: Remove the airbox snorkel on top of the airbox. It just takes a little prying and it's out. For $20-$40, you can get an aftermarket filter (UNI, TwinAir, No Toil), that will help increase airflow. Rejet one size up on the main and pilot.
      Here are the stock jetting specs to give you a basline:
      Stock jetting
      XR200 (not XR200R)
      main 102
      pilot 35
      Needle position 3rd groove
      Pilot screw initial setting 1 3/4 turns out
      XR200R (81-83 only)
      Main 138
      Pilot none
      Needle position 3rd grove
      Pilot screw initial setting 2 1/2 turns out
      XR200R (86 and later)
      Main 112 (86) 110 (87 and later)
      pilot 38 35(98 and later CA only)
      Pilot screw initial setting 1 1/8 turns out
      When these things are done, the bike will breath much better. This is the single greatest modification for a bike ridden at high altitude.
      Overall cost w/out filter: about $10 for jets; $20-$40 for the aftermarket filter
      ENGINE: The greatest improvement to the XR200R engine is a big bore kit. Here are the 2 most common kits: http://www.powroll.com/P_HONDA_XR200.htm
      Other options include porting and polishing the head, high compression pistons, hotter cams, etc. The more you do, the more reliability is reduced, but it is a trade off for power. Another option is an ’83 -’85 ATC200X cylinder head. It has a .5mm smaller bore, so it would need to be bored to 65.5mm, however, it has much larger cooling fins. For motors that are constantly being run in extreme temperatures, this is an option to consider.
      Overall cost: Varies by modification, expect to drop $200-$1000
      EXHAUST: There are several aftermarket exhausts on the market. These range from silencers to full systems. Prices range from $80-$500. Most aftermarket exhausts will give about the same improvement. The engine will rev quicker, which can be nice, but mostly they all just make the bike louder. For mild improvement to the stock system: grind the weld off of the inside of the header and remove the small cap held on by 2 8mm bolts at the exhaust tip.
      Overall cost: 0-$500
      SUSPENSION: This is a major weakness with '92-'02 XR200s. The first option for the forks is to give the springs more preload by adding a larger spacer on top of the springs. The second, most common option is to swap out the entire suspension. '84-'91 XR200 forks and rear shocks will bolt right up, and ‘81-’83 XR200R forks will with the corresponding triple clamps. '84-'89 CR125/250 front ends will bolt up to any XR200R with the addition of a spacer. This particular swap is more complicated, but also adds a disc brake and improves the bike tremendously when used in combination with an '84-'91 XR200 rear shock. See this thread for more info on CR front ends: http://www.thumpertalk.com/forum/sho...1&parentpage=2 These parts frequently show up on Ebay and can be obtained very cheap. Also, a visit to racetech.com or similar suspension tuning company couldn't hurt with any setup. Emulators and progressive springs will get conventional forks nice and plush. Currently, XR250 rear shocks are in question as to what years will work; therefore, I do not recommend them at this point. Many people have them on their 200, however there is not a definitive answer for the years yet. Be sure to research before you buy.
      Overall cost: Generally less than $100; for Racetech tuning, expect to drop $200+.
      WHEELS: An 18" rear wheel from an '86-'89 XR250 will bolt right up. This can help because the 17" wheel spins too much sometimes, and tends to work its own spokes loose. There is also a much greater tire selection with the 18" rear wheel.
      LIGHTING/DUAL SPORT: Lights can easily be added to the 200 by tying into a pink wire that just comes up under the tank, then loops right back down to the stator. This wire has no purpose, and was left behind in the wiring harness, because the non-American XR200s had lights, and Honda didn't pay to change the wiring harness or the stator. I have personally tested it up to 75 watts, but I wouldn't recommend going much higher. From there it is simply a matter of wiring it the way you want it. In any application you will need a 12v voltage regulator. I would be happy to assist with any questions on the wiring you may have, since I have redone mine several times to change things. Also, please visit this thread for some diagrams (about halfway down the page): http://www.thumpertalk.com/forum/sho...d.php?t=431097 Each wiring job is different, so it is difficult to write a generalized way to do it. For dual sporting, there are kits from Baja Designs and similar companies, or you can be creative and pull parts together yourself, and in result save lots of money. The first time I had lights on my bike, it only cost me $6. A speedometer cable can be attached to the speedometer port on the front brake hub, as long as you can find a way to mount the speedometer. TrailTech computers are the easy alternative to the manual speedometer.
      Overall cost: Dependent upon creativity. Baja Designs kit runs around $450
      Helpful XR200 Links:
      www-staff.lboro.ac.uk/~elvpc/papers/XR200.html (engine info)
      http://www.4strokes.com/tech/honda/lightup/ (adding lights)
      **I need more links for XR200 INFORMATION, NOT PRODUCT websites....Post them in this thread if you have them***
      Again, please feel free to suggest editing....I'm sure there are MANY things I forgot. This is just a baseline to get started.
    • By Footy
      I don't have photo access yet but lets see your 200's.
      My dad is planing on selling his 02 XR 200, but it's in need of a rear shock. I was told that these shocks arn't servicable, so we priced a new one out. The dealers asking over $400 for a new one. So my question is, what other bikes have a rear shock that will work on his 200? Thanks.
