Another 2 Stroke Jetting Question
I have a 97CR250 with a Keihin Carb. I have a service manual. I was trying to get my needle jet out. I unscrewed the top cap and the spring and the cable are in the sleeve. I pulled the sleeve out and can see the bottom of the needle jet sticking out. The cable runs down the middle thru a 6mm head. The service manual says to push down on that head and turn, the only problem is that I think I need a slotted socket so I can get around the cable. Is there any other way besides using a tool to get this needle jet out of the sleeve?
Thanks,
Mike
you pull up on the spring and retainer and then you push the cable down and it comes out a slot in the slide screw and now you can let go of the spring and you have the whole slide in your hand and can take a 6mm socket and 1/2 twist the scrwe and neddle out and there you go.
