anti freeze leak
alright so i noticed i had a little antifreeze leak and it was coming from that telltale hole. no biggie order all the parts to fix the water seal and then some because i was told to do it all at one. water seal, oil seal, shaft, bearing, impellar. parts should be in tommorow and i will be ready to ride. now my two questions are what kind of damage could this have done to my motor. i noticed it and fixed it right away but am not sure how long it was happening without me noticing. and for that bearing i need to put back in the case will the old find a socket that fits the outside of the race trick work on this one or should i get it pressed in?
thanks for any help
adam
Put your bearings in the freezer for a couple hours, install them immediately after you remove them from the freezer and they should slide right in.
