clicking noise in forks
hey everybody.. i just got my tire back with a new tube. i just took it out for a little test ride around my driveway. well i started noticing a clicking noise in the front forks.. it only happens if i really try to compress the forks.. it seems to do it once on the way down and once up. it makes both clicks in the same spot.. i don't know if its something inside the forks, or if its a wire or something tapping something when i compress them. while i was installing the new tire i notices that each fork would wiggle some which i didn't know.. did me wiggling them side to side hurt anything. the fork operation is still smooth and everything just a little click. also you really have to compress them to with in an inch or two of bottoming
