Drz 400s
anyone got experience with the carb?
this kinda runs like when you overfill the tank and fuel get into the EPA unit. (Yes it's a CA model)
I opened up the exhaust a little, sounds like a hefty thumper but now it seams to cut out and miss around 4-5,000rpms.
I don't know if it has anything to do with the opening up of the exhaust or not?
any expert help would be great.
Thanks
Welcome to TT :naughty:
Nothing to do with the exahaust opening you did.
Its lean from the factory to meet emission standards. :naughty:
Take a look on this http://www.drz.info/drz/ This is what you need to do and your problem will be gone. In fact it will be snappier and more powerfull.
Do the 3x3mod and DynoJet it its the #1 mod here
4000 to 5000 rpm miss -- Does it rev thru the range where it misses? or is that as fast as it will spin?
Thanks Deman,
The guy that had it B4 me did a dyno kit...
not sure what Main jet is installed or if he did that 3"X3" box mod.
Will check and advize
thanks
Mark
Well,
4000-5000rpm is my guess since no tach.
it revs through but starts missing the whole way up.
