paint coming off of frame
When I washed my WR the other day I noticed that there was a good size paint chip that fell off where the drain bolt is from the frame. My question is how can I fix it, Would spraying the frame with spray paint work? :naughty:
If it does get rusty how would you remove it, take a file to the frame or is there another way?
No! Don't file your frame! Use steel wool or emery cloth to take the rust off.
I rub all the bare metal spots on my frame with WD-40 on a cloth...takes rust right off and prevents new from appearing. I'm not picky enough to repaint those spots (yet anyway).
Do you have to put primer on before you put the paint on.
You should it will stick better.
