Rear Mono Shock
Help, riding down in Brazil and after trying 30 times to repair the progressive suspension rear shock, I am putting the original new one for my KLR650 back on. Unfortunately my friend brought it with him on a visit from the US but had to remove the nitrogen in order to get it on allowed on the plane. As such, he tells me liquid came out, that "in no way" looked like hydraulic fluid instead of just compressed air. Is this possible? Liquid Nitrogen too? I don't believe it but he is insistent. Anyone have experience with the original recharging and refilling it? What must I do? I assume I am now low on fluid and out of gas. How do I fill it properly and then, what pressure of Nitrogen if I can find a shop to charge it. If I cannot, will it run ok with normal air pressure? Regards. 2.5 years on 2 wheels across all the Americas... but still challenged by this KLR, Steve
Your friend may have opened the fluid bleed screw instead of the nitrogen fitting. If he did, the nitrogen bladder will most likely need to be replaced as the high pressure in it will have burst the bladder when the fluid was released. I've done that.
Ride on
Thanks for the idea, but no, I am sure it was the pressure stem... the one under a plastic cap, up at the top of the shock. The stem looks like a tire stem for air. Has to be that one, although it was under a black plastic cap that needed wedging off.
Is there a rubber bladder that would normally keep the fluid and nitrogen seperate...
Either way, how can I refill this thing now to make it work...
The reservoir that the "air stem" is located on has a rubber bladder in it. The bladder keeps the nitrogen and fluid seperate. You will have to find someone with a nitrogen tank, a high pressure regulator, and chuck to match up with the "air stem". Use around 150 lbs of pressure.
Good luck
Thanks. I am still wondering though, as the Kawasaki shock I am going to put on was brand new, why would oil have sprayed out of the nitrogen fill stem when releasing the nitrogen? Does that mean there is a problem or a leak inside or normal?
And, how can I fill the shock again with the proper amount of oil (130ccs of 5w someone told me) without fully disassembling the shock? Any ideas are very welcome. Regards, steve
Oil coming out of the nitrogen filler valve is an indication that the bladder is punctured. To inspect the bladder, release the remaining pressure, put a short piece of metal tubing or a socket over the valve (it must not touch the valve) and lightly tap it with a hammer. That will push the end cap down so that you can remove the springy wire ring that holds the end cap in place. Next, you WILL NEED something that is drilled and tapped with the same threads as the nitrogen fill valve. Screw that onto the valve and carefully pull the end cap out. The nitrogen bladder will be attached to the end cap.
Ride on
  • Similar Content
    • By Josh Munn
      Hi guys i recently bought a klr600 thats was running but had issues the guy i bought it off had fitted a manual timing chain adjuster but it had jumped a tooth and would hardly run i fixed that but it seems like the timing is retarded any one had this issue not sure what it uses as a pick up or if it has an auto advance. Cheers
      I also own a 81 xl185s, 81 xr250, and a 83 xr350. Cheers
    • By CantleyCustoms
      Hello guys,New to the forum.
      Quick question,I have a 1994 klx650c i recently purchased and am in the process of upgrading it.
      Have a trial tech vapor speedo ready to fit,however just wondering about the stock instrument gauges etc.
      Is it literally a case of unplugging the old dash and fitting the Vapor? Is the Dash used to complete the stock wiring circuit? e.g-if i unplug it and leave it unplugged is it going to effect the running of the bike? What about the dash lights,how would i go about wiring these up?
      electrics really isn't my strong point,got the basics covered but way too complicated for me.
      any help greatly appreciated,any more info you need please feel free to ask.
    • By rodrigonehme
      Hello, This is my first post and I'm new to TT.  I recently acquired a 2008 KLR650 (which by the way I absolutely love) and I'm working on adjusting my valves, I already measured its clearances and found this helpful online calculator: however I'm unsure of what the shim factory setting size is and it is essential to get the right shims. Does anybody know what the factory settings are?
      Thank you!
    • By RT_Chris448
      Recently we did a project bike with Dirt Bike Magazine's KLR650 and we were pretty excited about the results.  Check out the article on this fun project here:
    • By DougBurgoyne
      Hey guys,
      A super duper THANKS for all the help, laughs, and fun I've had here, and the bike I put together based on advice and lots and lots of reading material you've provided on what is the best vehicle forum I've ever encountered (been on many over the years). .
      Just when my bike was absolutely the bike I wanted it to be, my riding buddy (who is my father in law) bounced of his DRZ well up 4610 here in Oregon and broke his leg, and good. Tib/fib  job requiring rods, screws, plates, and a kitchen sink to put back together. If it wasn't for the MX boots I got him, and "forced" him to wear....there would have been all sorts of nastiness sticking out of the skin. No doubt about it, as both lower bones broke at sharp angles making spears inside his leg. As it was, everything was contained. He is going to be down for quite some time. I bought my drz to ride with him initially as he had a KLR650 and had an interest in backroad and moderate trail riding. On our first trip out (Brown's camp easy/mod trails) after about 10 times picking up his KLR with over-inflated 50/50 tires (mine stayed on 2 wheels all day long) he said "I need a bike like yours". Within a week he had his DRZ too! Then over the fall and winter we did all the mods and fixes to get them ready for this spring/summer.  It was kind of a miracle I even convinced my wife to let me get a dual sport bike. I'm 50 now, and have a degenerative vision disease called RP. Basically, I'm missing quite a bit of my vision field, but have decent vision straight ahead (unlike macular degeneration). I'm not in denial that good/full  vision is important for safe motorcycle riding on the street...and the reason I'm a 90/10 dirt/street guy. My argument was that we won't get hurt just poking around the woods, old man style, with occasional pavement work to connect trails (thus the need for dual sport over dirt bike).  Well, my father in law shot that theory down, but good!  He has dealt with so much pain over the last month, and met several dual sport riders in for riding injuries (some that make his look like a kid's day camp) that he decided he is out of the game. Unfortunately for me, that means I'm out of the game too. My wife is so worried I'm going to get injured badly, that it's not worth the fight. I don't want her and my daughter stressed and worried every time I go riding. My father in law was doing great on the roads and trails we've been riding. And just loved riding the DRZ. But he's 70 and looking at Jeep Wranglers with lift/tires for his forest adventures going forward. Not a bad call imo.  So...I've sold 2 DRZ's and a KLR in about 1 week (here in Portland OR, I could have sold 4 more DRZ's in the same time if I had them!).  His 1100 Honda shadow cruiser is on C.L. now as he is cleaning out the stable completely. Sad, sad day. It's only been a month since our last ride and I'm already missing the dirt big time. Even sold my daughters doodle bug. Oh well, life goes on.
      Take care guys, ride safe (inside your skill level), gear up...and have some fun for me!!
