DRZ header help
Hey I need some advice, I have a white bros pip and I am running the old header on it. It is starting to rust a bit and I wanted to replace it with something better any sugestions?
Buy a "E" header from www.ronayers.com for about $120. Search through their micro fiche.
Do you use an E header? If so did you see any performance gains?
I have a Yosh slip on and installed an E head pipe. Can't say I noticed any difference at all. Surely not as noticeable as the slip on change, or the hot cam change, or the E base gasket change, or the 3X3 Dynojet change..........
I read somewere that a good header will give you a boost in bottom end power. Does anybody know anything about that. Or should I just replace the stock one for much cheaper?
The head pipe is very restrictive in either the S or E (3mm larger in diameter). A good after market (muzzy or yosh) full system will provide you with significant gains. Not in overall hp, but in responsiveness. Properly jetted and with a muzzy system changed my bike from day to night.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
