yz fork swap help
what size spacer do i need below the upper clamp i heard 3mm but its not enough is the lock really neacery thanx.
The lock isn't necessary. you can buy the spacer from prc. Without the loc you better be checking it to be sure there is no slop though
thank you, i will check it so it doesn't oval the head tube
