Mistake with fuel screw?
DRZ400e (04)
Installed the JD JETTING. worked as advertised. Removed the off idle bog and helped H.P. The problem began when I removed the stocked fuel screw and repaced it with the ZIP-TY FMS02 fuel screw. The off Idle bog has returned and I have been all the way in and all the way out with little results.
CARB CONF for 1500 ASL: Blue needle #3 162 MJ Pilot and air stock the stock Fuel screw was at 2.5 out. Ran great.
Whats up?
Did you get the o-ring, washer and spring back in correctly? Which model screw did you use?
The O-ring, washer & spring looked good and correct. Screw type ZIP-TY FMS02
still need help
go to clip 4 blue.
Thanks Burned. Your alway there to help
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
