Fuel Screw? Help
DRZ400e (04)
Installed the JD JETTING. worked as advertised. Removed the off idle bog and helped H.P. The problem began when I removed the stocked fuel screw and repaced it with the ZIP-TY FMS02 fuel screw. The off Idle bog has returned and I have been all the way in and all the way out with little results.
CARB CONF for 1500 ASL: Blue needle #3 162 MJ Pilot and air stock the stock Fuel screw was at 2.5 out. Ran great.
Whats up?
Jason
The stock fuel screw has a very small o-ring, flat washer and spring
that has to be installed onto the new Zip-Ty fuel screw, could you have put it in without these ?
