Weird valve noise
ok so its my first time checking the valves and probably gunna have to shim aswell for the exhausts , but i noticed some really weird noises when turning over the bike with the valve cover off. firstly one sounds like a gurgling noise (like blowing bubbles into cup through a straw) , second one sounds like an air leak some stage as i kick it over.
im just a tad nervous/paranoid about whatever noise i hear coming from this bike lol. also what jets do u recommend i get for 0 - 500ft altitude , all stock 04 R.
heres the readings i got , what looks like it needs a shim?
r exhaust - 0.010
l exhaust - 0.011
r intake - 0.005
l intake - 0.005
i wasnt too sure on the exhaust readings , is the feeler mean to slide in freely straight away? or do u slip it under first then feel how tight it is? the shim kept hitting it when i tried to slip it under , but they were able to move once under
All the graphic oil and air pumping sounds are normal, no problems.
r exhaust - 0.010
l exhaust - 0.011
r intake - 0.005
l intake - 0.005
The spec range for intakes is 0.004" - 0.006" and for intakes it's 0.010" - 0.012". All your measurements are in specification, so don't shim anything. Just keep checking them regularly and shim when anything moves out of spec range.
Using feeler gauges is really an exercise in judgement; I like to feel slight resistance as the gauge slides between the two parts.
I agree with skipn8r, everything looks good. Keep checking the valves regularly and the bike should be good to go for a while.
