450X -can I get ride opinions please?
I'm beating my CRF250X to death here in the desert, but it's so light weight and fun to ride. :naughty: My DRZ400E has all the motor I need for the desert / trail riding, but it feels so heavy it tires me out too quickly. Is the CRF450X the perfect bike, the one bike that does it all? Does it feel light to ride, smooth power that just keeps on pulling, don't need to shift it constantly? My 250X has great suspension, the DRZ isn't very good in comparisson.
Is the 450X a slightly bigger and easy power version of my 250X, :D :D :D or is it a BIG bike that gets HEAVY as the day gets longer? :naughty: Should I trade-in 2 for 1???
I don't know about the 250x but had a drz400e and the 450x will do everything it did for you and more. It feels much lighter and pulls much harder. I think this maybe what you are looking for if you are looking for one bike. I loved my DRZ but the 450X is so much better IMHO....
I had the DRZ400s awhile back, first year it came out I think. It's a definate turd compared to my 450X. The 450X is the most fun I've had on 2 wheels. Way easier to ride than my YZ426. It gets a little heavy in the really tight stuff, but that doesn't make it stop being fun.
I can ride farther, faster than any bike I've had before. Just my opinion. Hope it helps.
:naughty: Had mine for a month, Rode it once on snowmobile trails before spring sprung in N.E. and have ridden it on trails 4 times since then. I ride a wide range of terrain - Class 6 Woods Roads, tight trails, mud, rocky and root infested trails, along with rocky up-hills. I have about 170 miles and the suspensions broke in at about 125 miles. Stock, the forks are stiff due to the fact that they do not use the last 3 1/2 - 4" of travel, ( adjusted Comp from 16 out to 24 ). My weight is 175 lbs. w/o gear and all the gear I wear is about 35 lbs. ( I wear Tech 8 Boots, Fanny Pack w/everything along with a Back Pack ). Despite all this weight I could not use all the travel. Checked the oil level and it was set-up at the factory specs so I lowered the level to 306cc which is the min. oil level. Still did not use all the travel even when hitting deep whoops and rocks at speed. Decided to change Fork Springs from .47 to .45. Rode yesterday and Forks felt much better with comp set at 16 and Reb at 7. Now using all the travel and forks felt much much better and almost plush. I only had a short time to ride and I feel I can make them work really good by just using the clickers. Awesome Motor, starts easy, and handles everything I throw at it with ease. With the Carb and Trans Vent Kit I installed the bike is a virtual submarine - had it in real deep water with the exhaust pipe submerged and it didn't miss a beat. Hadn't mentioned the shock because the rear soaks up everything thrown at it. No need for a re-valve there.
Won't get a chance to ride for a couple of weeks to fine tune the Forks. I could live with them the way they are right now!!!!!!!!!!!!!! I do want to play with the sag though. I started out at 106mm and then tried 102mm. I plan on trying out 100mm next.
Bike was a bit tall for me, ( I'm 5' 7" ) , so I shaved 1 3/8 - 1 1/2" off the seat. This also lowered the center of gravity on the bike and makes it turn easier in the tight trails ( when seated ) along with giving me added confidence when I have to touch the ground. I had a 2002 CRF450R and had the suspension lowered 1" and I was never happy with the way it handled after that. I won't make that mistake with this bike!!!!!!
It is about 20 lbs. heavier than the 450R I had but the magic botton is worth the extra weight. :naughty:
It is about 20 lbs. heavier than the 450R I had, but the magic button is worth the extra weight.
The 450R is similar in weight to my 250X. I love that lightness. :naughty: How does the 450X feel with that extra 20 lbs? I'm hearing it feels a lot lighter than my DRZ, which is what I want, but does the X still feel heavy on the trail compared to the R?
The faster I ride my DRZ, the heavier it gets. The faster I ride my 250X, the lighter it gets. Is the 450X the best of both worlds? :naughty::D
Just pickup a DRZ400 on the show room floor and then pickup the CRF450X and you will feel the difference in weight. The 450X is heavier than the 450R but the faster you go the lighter it feels. I only notice the weight when going slow or through tight wood sections with alot of turns. Once you got used to it I was going through those same sections as fast as or faster than my KTM200exe because the motor is so awesome.
Hey bob, If you ADDED 3cc's of oil and set your sag @100 not 105 not 103 but 100 you will be amazed at how supple the fork will feel and how well the bike will steer. To the original poster,the DRZ is old slow and weighs a ton,sell it and get the X if you like red,get a WR if you like blue,and if you like to diddle lil boys get a KTM.....LMAO
The DRZ is old slow and weighs a ton,sell it and get the X if you like red,get a WR if you like blue,and if you like to diddle lil boys get a KTM.....LMAO
Ok, can you KTM boys show some restraint, and not dignify his rude attack with an answer? :naughty::D
I did a search on brakes and found a great thread from about a month ago that got diverted and actually answered my question. It's time to sell the DRZ and get a 450X! :D:D:naughty:
Hey motoinmoab:
I hear that Michael Jackson rides a KTM, any truth to that?
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
