RM Front Fender - Color Question
Looking at buying an RM Front Fender in Yellow.
But it apears they have two different Yellows.
They have an 01 yellow and an 02 yellow...
Which one matches the DRZ yellow?
Which year is yours?
its an 03 and its blue..
I am ordering all new yellow Acerbis plastic though
And the yellow plastic says for DRZ400 years 00-04
I am also ordering an IMS 3.2 Gallon tank.. and the yellow code on that is Y3
My guess is IMS has given you the 2003 DRZ & RM yellow. Acerbis on the other hand aren't very sure of themselves. Get the 03 RM front fender to match ya tank. :naughty:
what I understand is that the IMS 3.2 in color code Y3 will match the acerabis yellow for the DRZ400 00-05.
When you look at the RM Front Fenders from Acerabis...
You have two options...
RM 01-05 Front Fender - 01 Yellow
RM 01-05 Front Fender - 02 Yellow
I am just kind of wondering which yellow to get.. If I were to guess... and It looks like I might have to guess because I am impatient and my money is burning a hole in my pocket. I would say the 02 yellow
Yup the 02 yellow! Sorry my bad... 02 and up are all the same. :naughty:
its now official.. my bike is turning yellow...
I ordered all new yellow plastic with the RM front fender and a Yellow IMS 3.2gallon tank
I'm partial to the 01 yellow myself that's what my E is. The 03 SM had a SM fender burned got for it. I don't know it's parentage except it looks cool. prairiedawg :naughty:
Care to trade, I have yellow and want blue?
too late.. already ordered it...
Also.. my front fender has crap loads of scratches.. i doubt you would want it...
But my rear fender is in good shape.. my shrouds aren't too bad but they do have some scratches
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
