Front Forks !!!!help!!!!
I have an 05 yz450f and I am have trouble getting the suspension balanced. The rear feels good but the front feels soft. Any advise on what i should do w/out sending them of for springs and valves. OH i weigh about 205 and I'm 6'2'' :naughty:
They are supposed to feel soft.
Are they bottoming?
Describe what you mean by soft.
They bottom a little but mostly when i jump the bike stabs in the air (nose down)
Did you have a 2 stroke before this bike?
Yes i did ??? what are you thinking????
You are probably letting off the gas (slightly) on the face of the jump.
With a big 4 stroke you have engine braking that will affect the bikes attitude off the jump. A 2 stroke will free-wheel when you let off the throttle. Try keeping the throttle on until your rear wheel is off the ground.
:naughty:
I did role on the throttle on my 2 smoke but with this new bike I blurp the throttle a little on the face of the jump still kinda intimidated by the bike. So you think it is me not my suspension??
I'm no expert, but I did stay at a Holiday Inn Express last night. :naughty:
Give it a try and get used to the bikes characteristics before you "jump" to conclusions.
:naughty:
Hey, Thanks I think i will try what you told me but i am still going to fiddle with the suspension some. Thanks
AWSOME!!!!! :naughty:
Usually when I jump off a smooth face jump I just stay steady with the throttle and just ride off the lip like I was just riding forward, maybe some preload if I have to...
you might be able to stiffen up your compression dampening to slow down the from end . But I think your bike is flying funny b/c you have to use the throttle on the face a little more . Bike control is a little different on a 4 stroke . Good luck
