Building a 4 Stroke that competes with KTM 50s?
Hey guys,
I am looking into upgrading my son's '04 CRF50 to try and compete with the KTM 50s in the PW4-6 classes. I know that it might be easier to just buy him a new KTM Senior but I don't want to spend 3K on a bike that I have to fiddle with all the time (i.e., clutches, new parts, etc.).
The CRF is lagging behind the KTMs in 3 main areas: power, suspension, and weight.
I figure since the big 4s get to run twice the CCs then, I should be able to run at least a 100 cc 4 (maybe a 110) against the 2 stroke 50s.
My question is would an 88 big bore kit or a 110 kit make as much HP as the KTM 50s? If so, are there any shocks and forks that can be adjusted for a kid weighing 60-70lbs? Lastly, are the aftermarket frames and swingarms significantly lighter than the stock components?
I was thinking that I could also throw a 3-speed manual transmission on it too. I just think that it would be really cool to have a little thumper out there on the track banging bars with the 2-strokers. What do you guys think? :naughty:
You can build a xr50 that will lay a whoopin down on a xr200 if you want.
A 88 Race head motor should be plenty to lay it down on those KTM 50's no problem.
I used to Run a 88 Racehead before I went to a 108 and I weighing 120lb's could run with 80's, now with the 108 Ill really be flying hehe. has all the motor stuff you should need, send me a PM as I can get you a better deal on them.
Suspensio wise, some BBR SP5 forks with stock xr70 springs or one stiff BBR and one stock 70 springs should make the front end nice for a little guy. For the rear, I would say a +2 swingarm, I have a nice aluminum Foes Racing swingarm for sale for $200, $150 less than new, and also probably contact Works Performance and they can build a shock to exactly suit his weight for about $300.
I have an 88cc Takegawa R-stage setup that you could put on that bike and whoop them bad. I took it off to go to a larger setup. New they are 880 (990 when I bought it)before another 200 for a cam from classic honda. I will let them go for 600 plus shipping. I will also throw in brand new rings and gasket set. If you are interested let me know and I can save you some money. As for the suspension stuff sounds like i would go with the swingarm he has. I have a set of stock forks with HD springs that I would take 90 for.
Lol, not even close to how much Ill save him. I can sale him a 108 stroker for less than that.
HONDA? I was just trying to clean out the parts in the garage and save someone some money. If you have Honda bottom end 108's for less than 600 bux I may be in the market for one...
well tb 88 race head and stroker kit is 108 (thats prolly what he is talkin about) and its probably less than 600...
Yup, complete Hondatrailbikes 108 strokers for under $600.
Do you really need a oil cooler with the 108 kit, i have heard both answers and looking for the right... thanks
Sorry, answered my own question while browsing TB web site....... Jester, does the TB 108 kit come with a bigger head? what power difference is there between the 108 and the 88 w/race head? Thanks
I was thinking that the way he answered the question he meant a turn key motor.... Granted you can get a 108 stroker setup for under 600 but how does the TB stuff stand up to Takegawa R-Stage. Just asking cause I have never used TB parts.
TrailBikes parts are great, before upping to the 108 I had the 88 Race head in for over a year without a single problem, the quality is identical to Takegawa or Kitaco.
Yes the TB 108 comes with a Race head and the power diff between the 88 and the 108 is amazing. It will easily walk away from the 88, there is just so much more torque and power everywhere.
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
