help with turnsignal relay !!
Hi, put miniblinkers on with built in relay. Need to disable the existing relay on the bike! Can you help me? I have the electric plan but cant make much out of it! Can you help me?
Oh a new question. I like it. From the trun signal switch on the left hanblebar, find the light blue wire. That is the wire from the flasher to the R/L switch. Cut the wire. Insulate the cut end that comes from the relay. Jumper the other end to any orange wire. You have now eliminated the flasher relay. Any time you select R or L turn you will have constant power to the signal lights. You say each light contains its own flasher unit???
yes it does, they are pretty nice but not really legal! thanks!!
share the URL with us?
mmmm tritip sandwhich
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
