Sator output of E & S?
Looked at previous posts w/o luck.
If both outputs are the same let me know, cause then the values are not so impurtant to know.
got off KLRs :naughty: ... and getting on DRZs :naughty:
Suzuki published specifications for alternator output: Kick start - 150 watts. "E" - 200 watts. "S" - 200 watts.
Cool :naughty: , so there is good power output in both E & S.
Thanks Noble!
  • Similar Content
    • By Markl5557
      So I am going to put in an in-line fuel filter just for added protection from stuff in my gas .... and I have always used bronze element cone ones you no what I’m talking about the ones everyone seems to use but upon reading online supposedly that bronze element breaks down and doesn’t catch everything .... I have came across a moose fuel filter that has a fine nylon mesh just like what’s on the petcock filter ... any opinions on which is better ? Bronze element or mesh ?
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
