rekluse clutch adjustment
Installed a Rekluse clutch on an 03 yz250f. The clutch works great but after 5 or 10 minutes of riding it starts to creep while stopped and in gear and sometimes stalls when at rest and in gear, I have tried every adjustment between the clutch cable tension and perch adjuster. It's hard to shift into neutral as well. It's like it needs more cable tension but I have tried that. It seems to get better when it cools down. The clutch still works great while riding. Everything is checked and rechecked according to specs/instructions. I have called Rekluse on this as well. I have installed 2 on CRF450's that work flawlessly.
Any suggestions? Maybe 1 narrower clutch plate? :naughty:
What type of oil are you using? Stock clutch plates suck by the way, that could be your problem. Honda CR125 plates work much better than stock Yamaha plates.
Actually, I think the clutch type makes a little more difference than the oil. On mine and the stock clutches, I couldnt get the creep out of it. With the Honda clutches it has worked great.
I just went all out with my Rekluse rebuild on my 02 YZ280f:
8 new Honda CRF250 Frictions,
6 new Yami Drive plates
A Hinsen inner boss (to go with the Hinsen Basket that was already there.)
I set the clearance at about .037 for starters.
It feels great so far, instant hook up, and I can shift into neutral while I am stopped. So far so good...
RH
