Valve adjustment question on 450/510
When you're lifting the valve cover off, did you find it easier to lift the gasket off with the valve cover or to leave the gasket on the head and just lift off the valve cover?
Also, the manual compression release cable looks to be in the way, can you sneak the valve cover out the right side with the cable still hooked up or should I remove it and get it out of the way?
I asked the left side right side question too here and got back take it out the left side but the hose looks in the way. I took it out right side and did a poor job of disconnecting re-connecting my de-compresion cable as I brute forced it back in place I think stretching it's setting up top instead of disconecting it up top to give necessary slack as a thoughtful mechanic might do.
the gasket peels off half way with the top so I just peeled it off all the way before I did the valve checking. and then placed it back on as I re mounted the top cover.
let us know how the clearances come out. how many hours on your bike or miles? I will be doing mine this week as well at 45 hours.
Gasket stays on the head. Just make sure it gets back in the groove during re-install. Take the cover out the left side. Just gently squeeze the radiator hose to gain clearance and wiggle it out. Clean everything first! Including the wire bundle on the backbone.
If the cover comes out the left-hand side, I take it that you need to cut off the clamp on the vent tube connected to the valve cover and replace it with a hose clamp?
yeah those factory clamps are impossible to re set. I replace em with screwed hose clamps - hey that reminds me of another issue
I seem to have an oil leak on my 450. There's a trickle of clean oil drooling down the morot from the valve cover/head junction. I haven't gotten the tank off to look at it, but I am fairly confident that it is valve cover gasket. How could I have done this?
I decided to take the cover off on the right-hand side and leave the stupid clip alone. Anyway, I'm leaking oil from that metal clamp so it'll get tossed the next time I check the valves.
The gasket uses permatex to glue down on the cam wells on the left side so I left the gasket on the head but the gasket also has a grove it is supposed to stay in on the valve cover. It looks like it was supposed to stay with the valve cover but oil leaks happened so the factory started using permtex to sort out the problem.
The valves themselves were in spec with the exhaust being 0.18 and 0.19mm and the intakes were both at 0.15mm. Hopefully these will tighten up and not loosen up and save me some hassles next time around.
My engine has 7.8 hours on it and most of that time has been high rpm zoom, zoom riding.
The spark plug tells me that my bike is jetted way, way too rich out of the box.
I take mine out the right side.....gasket left on engine.....and decomp cable in place.
I just had to adjust my valves for the first time on the '05 TE450. It had 38.3 hours on it when I did the adjustment.
@ 18.4 hours:
R/L Exhaust @ .007in(.178mm)-R just a bit tighter!
R Intake @ .005in(.127mm)
L Intake @ .006in(.152mm)
Still within limits and starting/running great!
@ 38.3 hours:
R Exhaust @ .005in(.127mm)
L Exhaust @ .006in(.152mm)
R/L Intake @ .004in(.102mm)
They all needed to be re-shimmed. Luckily, Husky had my bike shimmed with four different sizes(LE-2.25, RE-2.30, LI-2.35, and RI-2.40). Therefore I just had to move each one over one and throw in a 2.20 in the LE and call it good. Cost me a couple bucks and I had to do them all. Worked out slick like that. Just have one 2.40 I have no use for at the moment.
New measurments are:
R/L Exhaust @ .008in(.203mm)
If you haven't done your own yet don't be intimidated at all. It's really easy. I found that a pipe spring puller works real good on the rocker arm clips. Magnetic screwdriver on the shims. All the rest is a piece of cake!
Travis Epperson
thanks travis and eric for the the data. I suppose mine will need some shim work at 45 hours, but then again I'm not a high rpm we'll see what we'll see
my second valve check at 45 hours on my 05 Te-510:
My intake valves have not moved, still at an easy 0.005" maybe 0.0055 as easy as that 0.005 feeler guage slid in there. I recorded them at the same 0.005" at 12 hours. spec range is 0.004 to 0.006
My left exhaust valve clearance remains at 0.007" where I recorded it before. My right exhaust has tightened up just smigin to a clean 0.006" from what was an easy 0.006 or probably 0.0065 as I recorded it last time. The exhaust spec range is 0.006" to 0.008". Since I had no problem sliding in that 0.006" feeler guage under that right exhaust shim, I'm leaving it as is.
You do slided the feeler guage UNDER the shim correct? seems the only way to get it done. Ok ship shape all done. I'll look again at 80 hours, or if any hard starting develops.
I pulled the top cover out the left side, simply pushed that coolant hose out of the way - took a little wrestle to get it free, but I never had to disconect the rad hose or the de-compressor cable, only de doupled the crankcase breather hose as needed to lift the cover free. took about 10 minutes from cover bolts out till clearances checked.
Hooray Husqvarna. My valves are in spec at 45 hours, 700 miles, 2 months of ownership :naughty::D:naughty::D:D:cry:
Actually you slide the feeler guage between the shim(OVER the shim) and the rocker arm. You must be doing it right though as I can't figure out how to measure under the shim.
Travis Epperson
I just checked mine between the rocker and the cam lobe, am I doing something wrong here?
well heck it slides in where it slides in. maybe I can't see it well enough, but it looks to be going under the shim to me......jeez what if i did it under the shim and I should do it over , does is that result in different mesurement?
darn and I was feeling like such a good beginner mechanic too.
Nope. You're doing it right.
Now I'm confused! You're supposed to check it between(on top of) the shim and the rocker arm. I've never heard of checking it at the cam. Who's screwed up or does it matter?
Travis Epperson
who's on first? no who's is second, what is on first. what? :naughty:
I need a nice isometric view of the parts in there with the feeler guage inserted properly or a photo... next time someone does this right please take a picture & zoom it up for us.
I've always found it easier to check it between the rocker and cam. Things get very confusing with the noise of the engine and the oil spraying everywhere. So instead of trying to fit my fat fingers under the rockers and chance getting them pinched in the spring.
What RPM are you guys checking the shims at? I can't get it to run very well below "normal idol" to be able to get a shim in and out fast enough.
Plus: I have to keep filing the carb with gas while the tank is off.
These bike are much more trouble than I thought. But I'm getting the hang of it.
Huskytone, you're a cruel man. :naughty:
That's gonna help! Do you realize what you just did?
Travis Epperson
There's some guy in Denmark right now with shims flying across the garage floor.
  • Similar Content
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit:
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
    • By Ride
      ...thought this might be fun as i see a lot of older guys riding Huskys on TT. I'll start...
      41 years old - 93 TC610/99 WR250/02 WR250/04 TE450/04 CR125/06 TC250 (on the way)
    • By Dave Hoder
      I'm just putting the finishing touches on my streamlined version of the BOZZA DRAFT shop manual for the 610. I've removed everything but the english language & made it easy to find what you're looking for. I re-wrote the part about the computer with many thanks to Xfool but I'd like a little proof reading here. In particular I'm not real sure about the Service Interval section. If any of you would be willing to double check what I've got here & report back with any errors or omitions I'd be greatful. (I added another section on adding & removing screens) Also I don't know if it's legal to post this for public consumption but I'd be happy to share it with anyone who want's a copy.
    • By Agitator
      10/17/08 UPDATE! I posted more photos on page 2. Not all pictures are on page 1. I will constantly be adding more photos as I go along.
      Many of you have heard of my starting/idle problems with the 610. Carburetion has been ruled-out time and time again. I sensed something else was going on. The engine has never wanted to idle down, sounded like there was a load on it even in neutral. Since I had metal filings in my oil when I first got it, I have now decided to overhaul it and make everything ship-shape. It turns out that I was correct- there is some valve damage that I will talk about later.
      I don't like to take apart dirty engines and get the dirt inside 'em
      A little gross.
      My cleaning station:
      A little better now
      Clutch removal:
      after removing springs
      bottom of pressure plate
      everything looked decent as far as wear
      after removing plates
      basket after removing hub
      Area after removing basket.
      Removing the starter gear with snap ring pliers
      More to come. I'm uploading pictures of the case splitting, etc...
      I'll try to ease off on the photo-over-obsession. The next batch of info/photos will be a little more interesting.
      Comments and suggestions are appreciated. I'm already ordering parts from George so before I know it, I'll be just waiting on new parts (after a little more cleaning.
