hose from cam cover to air filter box...what purpose?
there is a 1/2 dia black hose runs from the right side cam cover top down to the left side bottom of the air box, apparnently up stream of the filter or tapped into the box but maybe outside of the filter rim?
bike was nearly up side down on a couple of hill climb crashes this weekend and found oil dripping from the bottom of my filter box
what is happening?
The hose is the crankcase breather. A little oil mist will come out of it pretty much all the time, so they route it into the airbox to keep it from going all over the place. Excess oil is harmlessly ingested into the engine. When the bike was ass-over-teakettle oil ran through the breather tube into the airbox. Voila, oil coming out of your airbox. Nothing wrong, just clean it up and, well, keep the darn thing upright.
thanks, why does the crank case need to breathe? emissions control? or other wise?
emissions control, thats it,s main reason so as to draw the fumes back through the engine and out the exhaust, burning them in the process makes for less fumes, less bad gas
A crankcase breather is required to exhaust the pressure build-up from piston ring blow-by. Compression leakage that gets past the rings would then pressurise the crankcase causing oil to leak out from where it can, EG: seals, gaskets, etc. if you didn't have a breather.
I've noticed on my 510 that the inside of the airbox rubber boot where the breather tube connects is always wet with oil. Its wetter than I would like but the engine doesn't seem to use much oil?
Some say that disconnecting this breather tube and externally venting it improves engine performance but I think it would be marginal if any. :naughty:
Ditto on what Thumpin said about what the breather is for.
My 610 had the breather vented externally through the front downtube, same as the gas cap breather. It did a great job of oiling my right boot and making a mess of the bike!! I rerouted it through a catch bottle and vented the catch bottle to right above the exhaust header. What gets out of the bottle gets vaporized on the header. Looks cool when I'm at a stoplight and there's smoke coming from the front of the bike. Having the breather go into the airbox is a good thing, IMO. Not sure if venting the crankcase to the atmosphere will make any difference in performance, but I do know it'll make things messier.
emissions control, that's its main reason so as to draw the fumes back through the engine and out the exhaust, burning them in the process makes for less fumes, less bad gas
There is more to it than that. Not only is there blow-by as another poster has pointed out, but when your piston is moving downward, pressure is building up and this pressure is parasitic to engine power. By providing a place for this pressure to go, the engine can rev quicker.
Tons of thought goes into this idea in the design of inline fours.
And clearly the crankcase breather could be bigger because my breather is weeping oil past the hose and clamp from high rpm riding on my SM510R.
Hey guys,I have the same problem with what looks like massive amounts of oil settling in my airbox. One thing ive been thinking about was re-routing the hose down towards the chain with a small foam filter (rc-car intake filter) and have what builds up trickle down and lube the chain... any input?
I disconnected the hose from the airbox and sealed up the airbox inlet. Stuck a K&N filter on the end of the hose and routed it up so it won't suck water. Also installed a krank valve that creates a little negative pressure (vacuum) in the crank case which in theory, reduces power losses due to crankcase pressure. Did this on both my SM450R and TE250.
the breather hose is the one you are speaking of. If you unplug it from the air box you will notice a bit of a gain in horsepower and throttle response. basically, it is feeding dirty air to your motor. you can re-route the hose down between the bottom of the motor and the skid plate. Over time a small amount of oil will drip onto your skid plate, but it is easy to clean up. Anyway, this easy mod will give you a 1 to 2 horsepower increase. Just remember to plug the hole in the airbox with something so you don't suck any dirt in.
Travis Epperson
Your first post and it's about HP gains from plugging a breather hose. Come on guy.
I have not read all the post, just a few that talked about oil mist. On a single cylinder engine the air volume below the piston pulses by the engines swept volume, 450 or whatever size your talking about. Thus as the piston goes down approx 1 pint of air tries to flow out that hose, then when the piston goes up it flows back in. As all the air can't make it out before the piston comes back up there is some pulseing in crank case pressure. As this air is flowing in and out of the crankcase it is important that it be routed to clean dry sorce as Husky has done. The KTM SX models route it to the back of the cases and there is an occasional problem of countershaft bearing failures on those SX models. Husky is a step ahead of KTM on that and several other engineering & design features.
I didn't say to plug the breather hose. That would make absolutely no sense. I said, disconnect the breather hose from the airbox, and plug the airbox where the breather hose was attached. If you don't think it will make any difference in how the bike runs, then don't do it.
sorry, just pushing buttons.
My 125 doesn't have that hose, so I can't try it
On my zx12r i connected the crankcase breather hose to the "clean air" system on the head.
A system of reed valves near the exhaust ports creats a vacuum, thus negative pressure to be created, within the crankcase.
I have seen a 6hp increase in hp (5k up), but that was on a 4cyl, 1200cc, 11,000rpm 190hp bike.
Many dragbikes use an electric vacuum pump to creat negative crankcase pressure, for the gains of cause.
I would be surprised if any gains are possible on a 1cyl, low reving engine but who knows???
  • Similar Content
    • By Mike Michel's
       Would anybody know how many watts my 99 TE 410 stator
    • By KX290F Pilot
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit: www.RockstarEnergy.com
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - https://www.rockymountainatvmc.com/docs/Brake switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
    • By Ride
      ...thought this might be fun as i see a lot of older guys riding Huskys on TT. I'll start...
      41 years old - 93 TC610/99 WR250/02 WR250/04 TE450/04 CR125/06 TC250 (on the way)
