what do you know? 400 sx too a 450?
I have a 2002 400 sx, I decided to find some aftermarket parts, primarily a pipe and some other things to try and get a little more power. I have come to a conclusion that there is some stuff out there but not a wide selection too chose from, at least for a 2002 400sx so MY question is this: are the engine blocks and inner workings the same on 2003 and newer, if so would it be a good idea to change the piston and connecting rod and etc? so that I could just look for 2003 parts? I have thought about a big bore kit but that still leaves me with this question, after the big bore kit, they don't have any pipes for a 2002 450sx? would i just run a newer 450 pipe and would the frame bolts line up? please any tips or advice company names etc.
the simplest (and probably less expensive) approach would be to get the 453 kit. i also have installed a thunder alley pipe (off road-spark arrestor type) and really like it.
The 400 pipe is the same as the 520 pipe. The head/pipe connection changed in '04 and the sx's changed in '03 so you would need a pipe from an '03 or earlier e/mxc or a '02 and earlier sx. Also a pipe in itself will not give you more power. it may make more power in certain RPM ranges but IMHO it won't give the kind of gains you are looking for.
The bottom end on your bike is the same basic botom end as all the RFS motors. In order to update your motor to an 03 or later 450sx you will need crank, piston, gaskets, cylinder, cam chain and cam.
I have a 453 kit avalible that is a bolt on kit and if you add a 450sx cam you will have almost the same power as the '03+ 450sx's. Do a search here and on KTMTalk in the 4 sroke section for "453 kits" and you will find many happy riders.
If you would like to discuss options for your bike you can pm me or call me @661-713-4295
thanks Travis, What about an ignition box
What kind of power are you looking for? The '05 sx box will fit on your bike and it does make a difference. More power off idle and pulls better through the mid and about the same on top. If you want to get really fancy try a vortex ign. It has 10 different power curves to chose from so you can dial in or out power accorting to track/trail conditions
I have a 02 400mxc and I but a white brothers r4 pipe and jetted it. the guy who had it before but everything off of the 450 engine on it, He said it bolted right up. So its really a 450
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
