Fork question on klx400
My forks deflect off sharp bumps like hard rocks, square edges... others have told me the klx for some reason has hard valving compared to the drz.. is this true? It's ok for desert running but at lower rocky, nasty woods trails like Kennedy meadows the deflection and bouncing instead of being pliant are a real pain.
Any suggestions?
the klx400 is 100% identical to the drz.its just a green suzuki.
Have you tried compression damping adjustment?
Crack open the air bleed screws to release excess air pressure?
Maybe try lighter oil and/or verify correct oil level.
I'll try the fluid change but I think it might be valving...
Get a steering dampner if it's really a problem. It'll make it easier to ride in the dez too.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
